Victoria Fender interchange
Vicky 1931
What fenders from other model A's can be used on a Victoria? Will all 30 31 aprons work as well as running boards? I hate asking all these questions, but I see parts locally lately and the online descriptions have left me confused. Thanks Again.
Vicky 1931
Any late 1930 through 1931 front fenders will work and be correct. The one piece splash aprons and separate running boards made during the same time period will work. Any sedan rear fender from 1930-31 will work. All Victorias were made after front fender/ running board/splash apron change in September of 1930. I encourage you to purchase the Restoration Guidelines from either MARC or MAFCA. It will tell you everything you need to know .
Also, I recommend that you join the Victoria Association (https://www.victoriaassociation.org/)
Bill
President of the Victoria Association.
Bigsnapper
There is no extra bolt hole in any of the 4 Victoria fenders that I know about. Victorias used stock Model A fenders. There was a hole added to the Model A front fender's rear flange in March of 1931 for hanging on the conveyor system (Restoration Guidelines 13-7).
there is one extra hole in the rear fenders for the rear valance. you can drill the fenders when you install the valance.
The inner fender web has a elongated dimpel in it as well on the S/W cars that the others did not originally have :)
But this pannel can be changed out to other fenders with a small amount of work if you need more like origanally built for those cars
