Victoria Dome Light Wiring Diagram
biggieou
Does anyone have a wiring diagram for a Victoria with two switches? I cannot find one anywhere. Closest I can find is the one in the Service Bulletins for a Town Sedan with one switch.
FSB pp.291,356,468 show single switch on right pillar for Fordor and Town Sedan. Doubtful the car rolled out the door with two switches.
If a switch is added it may be wired in series or parallel. Series requires both switches ON for light, either switch OFF turns it off. Parallel allows either switch ON for light, both must be OFF to turn it off.
That's all I could find as well. I'm going to wire in parallel.
Sent from my SM-N920V using Tapatalk
What a hassle that would be. Maybe it is wired as a 'three way', as in a house. But then 'three way' switches (SPDT) would have to be used, if available (doubtful).
on the Victoria`s that I have put together. the power wire goes straight to the dome light the ground wire from the dome light goes to the switch on the other pole on the switch the wire runs down to the brace that is riveted to the inter well panel
