Vicky windshield frame question
I just bought a stack of parts out of a garage, basically it was the whole car minus a body. A 1931 Vicky ( Apparently the guy was having the body painted, and the shop that was doing the work burnt down and the body was destroyed :eek:) Anyway; Im going to put another body on it, and Im selling off any Vicky only parts, so I was wondering if the windshield frame is Vicky only? or will it fit in any Model A? I want to make sure the specific Vicky only parts make there way to the guy who needs them.
The hood and chassis and fuel tank will be the same as any A of the same manufacture date (there is a body bracket on the frame that might be vicky only).
The remainder of the cowl, dash rail, windshield etc is the same as the slant windshield fordor, as are front door window regulators, and door latches.
Basically everything else on the body is victoria only.
While there are Vicky specific parts there are also Slant windshield specific parts on the body.
Your best bet to utilize the maximum amount of parts from the donor car is to use a slant windshield body. Things like original window regulators are rare for slant body cars and won't fit in just any other body.
Sucks about the parts I asked about.
The doors are 400A and vicky. The window risers and latches are vicky/400A which are like the slant fordor/cabriolet with longer arms or rod.
The frame will be for a slant window with the #6 bracket and the 2/3 holes rearward. The #6 brackets can be removed and sold if you are putting a striaght window body on the frame. It is worth your time taking them off.
The gas tank is vicky specific if it is an early '31... The steering column bracket is different.
Stephen,
Your answer to that question & Most all others for your Victoria are best found by joining one or all the following: the International Model A Ford Victoria Association- w.w.w.victoriaassociation.org ,(a ton of literature is available),
The Model A Ford Club of America- w.w.w.modelafordclubofamerica.org
The Model A Ford Restorers Club- w.w.w.modelafordrestorers.com as well as this forum and your local club. All are great resources.
There's so much support & information available.
Good luck,
Bob
I am new and not sure if this is ok to do. I have a slant windshield town sedan. I could use any good door locks and window regulators that you would like to sell.
