I don't know what's normal vibration to expect with an A. But it sure seems excessive to me. Mostly around 35 to 45 mph. You can feel it in the steering wheel, floor boards, hard to pin down. What I did find so far, the front motor mount springs are tightened down so far that there is no space between the coils in the springs. And, the bottom spring below the cross member is missing all together. So, I should have a new spring kit from Snyders tomorrow. I'll see what that does. Process of elimanition. As far as the motor goes, it's a fresh rebuild with less than 100 miles on it. Stock crankshaft, stock fly wheel, rebuilt by a very reputable engine builder thats done A engines for years and years. Could spoked wheels not running true cause vibration? As I mentioned before, seems worse when I let off the gas. Like James mentioned, could very well be the universal. After the front motor mount, I'll check out the universal joint.
