Don Cape Cod
Sometime ago I posted problems trying to figure how an engine could vibrate so unbearably. I tore down the engine, had it balanced, 95 grams were noted, put the engine back together, only minor improvement. Well, the only thing left undone was the cam shaft that had been reground. But that just did not compute. Now this engine was a rebuilt with few miles on it, but it had an FS electronic ignition. When you pulled a plug wire, it must have shot a spark an inch & a half long! I had worked on another 5 A's in this group with FS ignitions and they all worked just fine. However, in desperation, I yanked the distributor and stuck in a Henry original. Guess what? The vibration was gone! My fillings & crowns were still in my jaw. This puppy must have been doing some cross talk in the distributor and firing at odd ball times before or after when expected. I just don't know why. I'm just thankfull the problem was resolved!
Now I speak to this because I would like to recommend to you that if you install one of these ignitions, you work out a simple plug to provide a disconnect to the wires entering the distributor. You can then carry a Henry spare, prewired so that you can substitute it for the FS, with a few temporary changes in the coil & switch wiring.
I'll not take up any more room here but you're welcome to contact me for furthur information.
