Mike A Model
My objective was to replace my existing Model A distributor with a Model B distributor on my 1928 Roadster. I found a Model B distributor, sent it out for a complete rebuild and after a long search, found a good Model B timing gear cover. I replaced the Model A timing gear cover, which bolts directly to the front cross member, with the Model B timing gear cover and used the Model A thrust plunger and spring. As expected, when I removed the Model A timing cover it damaged the oil pan gasket. This however gave me the opportunity to clean and inspect the oil pan. Well, while I had the oil pan removed, I figured this would be a good time to rebuild the oil pump with new gears, screen and bushings. Which I did. Too make a long story short, after completing the work it was time to start the motor, which started and sounds good at idle. I decided it was time to goose the motor a little, when I did the vibration shook the headlights, fenders and any other loose stuff. Kind of troubling, in that before I made the changes the motor had some vibration, as with all A motors, but not like this. The only rotational change I made was to the oil pump. Any advice would greatly be appreciated.
Thank you,
Mike
Thank you,
Mike
