TJ
I've read all the postings and have a question. When you say it won't start are you saying the starter engages and won't turn over the motor? or are you saying that the starter does not engage at all until you depress the clutch? Could it be the "snap' you heard was the hot cable of the starter switch shorting out on the clutch pedal? The 36 has the starter switch placed between the brake and clutch pedals and maybe a cable loosened up and allowed it to come in contact with something metal? It's interesting that all appears to be fine once you have removed the floorboards.Think I will change the transmission oil before I reinstall floorboard. Transmission oil looked good and was at proper level.
Draining trans oil may shed some light on what happened.
Joe
