Very New
rnengnr
New member
Found a desert T missing driveline...... was toying w the idea of finding an ecoboost turbo plant and figuring a way to adapt to a mustang stick.....
i know this is not the accepted way to restore,,,,, "but thats the way i roll"..... only been researching this for a day or two but are there modern 4bangers rwd Fuel injected that will go in a T ?
i have access to a machine shop,,, lol and more specifically a great machinist...
RN
RNengnr@mindspring.com
Miami/Tucson
The hamb guys might think turbo engines are uncool, some of them are kind of judgmental about things like that.
But if the car you found has axles i am sure you can adapt something with only a modification to the driveshaft and pinion bearing and something under the frame for the front radius rod ball to be clamped into, plus the engine cradle. In an ideal world these would be 1 point at the front crossmember that can rotate slightly and 1 point on each side of the engine, nearer the firewall.
