19Fordy
Here's a pictorial of the 8BA crankcase ventillation system using the 8BA style intake manifold. If you install an electric fuel pump you can mount an oil fill tube and a road draft tube that would run down the back of the engine. Air passing beneath the road draft tube would pull air and gasses out of the crankcase. I recall seeing this on early Ford engines. The tube looked like electrical flex conduit but was larger in dia. The photo below shows an oil fill tube with cap I made . It mounts where the fuel pump stand used to be. If needed, a hole could be drilled in the side of the oil fill tube and a road draft tube inserted which would run down along side the bellhousing. The same thing could easily be made out of steel.
