Vent window 47 Tudor
don-wi
Need to remove the vent window from my garnish molding so I can install the new gasket. Do I take the nut and spring off the bottom? Then drill the rivets for the top pivot? Thanks Don
Solved. The lower pivot has a nut that has to be removed and the upper pivot has a rivet that needs to be drilled out.
I got the new rubber installed and need to install the 2 piece rivets that secure the rubber to the garnish molding.
