Pretty short for an A. They should be good at around 7000 rpm.
This resonance is set by the size. How to determine the size? I have not a clue!
I heard that 97s need stacks to run properly on an A so this morning I made these - and a sack full of swarf.
Brendan Correct BUT They are of larger cubic inch, Now on an A with two V8 carbs or more & being of small cubic inch ,there is not enough suck to pull in the required amount of air , & its my understanding instead of putting in smaller ventruies by using stacks it pickups air speed , I stand to be corrected on this , But before i fitted them on two carbs it ran like a bag full, once fitted the engine ran completly differant, On a sinlgle 81---97 not needed at sea level.
