Kevin in NJ
But if you have fuel purculating in the bowl forcing the float up preventing fuel flow is that vapor lock?
Jeez, guys, what's the big deal here???? When a liquids is changed to a gas it is vaporized. It makes no difference if you have a fuel pump, a gas tank 10 feet tall or a carburetor too close to the heat. If the fuel stops flowing because of vapor ANYWHERE, caused by ANYTHING, the darn thing is vapor locked!
Webster's says vapor lock is...
"partial or complete interruption of flow of a fluid (such as fuel in an internal combustion engine) caused by the formation of bubbles of vapor in the feeding system"
https://www.merriam-webster.com/dictionary/vapor%20lock
Plus 1 I'm with you.
How about this?? What if you soak the wooden clothes pins in water first, then when you clamp them on the fuel line the water evaporating from the wood will give an extra boost to the cooling effect. Armchair scientists may now chime in.![]()
Related to ethanol, vapor lock, and just thought I would ask: Has anyone thought of using AV-Gas (aviation fuel)? Pros vs Cons, etc.
