Reading in Dick Flynn's tec tips. April '84 there's mention of drilling a hole in the pump body to prevent vapor lock.
Anyone have a diagram of this and also has anyone done it?
Im interested on the feed back of this curious idea.
Vapor lock is the result of lowering the pressure on the fuel (because of the action of the pump diaphragm) and elevated fuel temperature. Once you exceed the vapor pressure of the fuel it starts to transform from a liquid into a vapor which does not pump or meter well. Not sure how drilling a hole anywhere is going to change the pressure drop required to move the fuel or reduce the fuel temperature (if what he was referring to was actually vapor lock).
With all respect to Dick Flynn, some of his tips are as though he had pulled them from his nether regions. This seems to be one of them.
Electric Fuel Pump is the only answer. Cars today have the fuel pump inside the gas tank to prevent vapor lock.
A gas return line from pump will also work. Manufacturers started using them in the early 60's, this eliminated vapour lock by keeping cooler gas going through the pump. You don't need an electric pump.
Modern cars have the pump in the tank as there running high pressure fuel injection, and submursing the pump removes the need for an extra swirl pot pre pump. Not because of vapour lock.
Martin.
