CalMI
My 36 does not like parades. Today for the third time it quit again part way into the parade route. Ambiant 65 degrees. I kept the flattie running by holding my momentary on switch on to run the electric fuel pump. I have no problem running down the road but if I stop and let it idle for 5 minutes it quits and it won't start until it cools down. and by the way I have checked for spark and have a strong spark.
I need help! My wife is threatening to not ride with me again.
I first thought that the problem may be the fuel lines picking up heat under the hood but now I am thinking that the fuel line may be picking up heat from the left side exhaust pipe. The fuel line follows the exhaust the whole length.
I do have a fuel line insulator sock from front to back but I am suspecting that it may not be enough to keep heat from getting to the fuel. My question is where are you all with dual exhaust running your fuel line. should I reroute the line or I'm thinking I could wrap the exhaust pipe with insulating wrap.
Thanks for your help,
Cal
Cal
