1952henry
George, your tests and analysis's are greatly appreciated. I'm sure you already know that or you wouldn't be doing them.What they do in fact is dispell or confirm long standing theories and/or myths, and provide food for thought about projects we can all do to stay on the road. I think this particular test is one of your better uses of mind power over mechanical impotence!
Now, food for thought regarding the 1 lb check valve you propose: I see no downside in its installation beyond just complicating a simple solution, but question the need for it in the first place. First, you reported that the sight glass showed no significant movement with the return line open or closed, so the reported engine spin of 4 or 5 revolutions shouldn't have been fuel related. Second, a negative pressure in the line theroetically could pull fuel into the pump as it is being sucked out, as both pump valves are forward directional. However, if the pump does in fact drain back, the fuel in the carb should be adequate to prime the pump again, wouldn't it? Perhaps these questions can be addressed at your next test run?![]()
You are referring to the fuel in the carburetor being adequate to start the car in order to get the fuel pumping, correct?
