Bob from Northport Well-known member Nov 7, 2023 #1 Saw some Harland Sharp valve train systems. Are these made for a stock 256 Mercury engine-1954???
KULTULZ Well-known member Nov 8, 2023 #2 Bob from Northport said: Saw some Harland Sharp valve train systems. Are these made for a stock 256 Mercury engine-1954??? Click to expand... HARLAND SHARP is a quality HI-PO manufacturer. Their valve-train parts are intended for a HI-PO build. You would also have to verify correct valve-train geometry ($$$) as the rockers are HI-LIFT. Are you looking for service replacement parts?
5 55blacktie BANNED Nov 8, 2023 #3 Ted Eaton (eatonbalancing.com) is the exclusive distributor of the 1.6 ratio Harland Sharp rocker arms for Y-block engines.
