29FordGuy
I remember when my first car started having a bit of valve tappet noise, I'd go down to the Pep Boys and buy some stuff that was supposed to free them up....and it worked. Now my A has it and I can't seem to shake it. Thought I would querry this before I go and do something stupid.
The engine was rebuilt a year ago but since the car was still being restored I did not run it much until recently. It ran fine up until a month ago when the valve noise began. I am wondering if I should find an additive to free up an assumed sticky valve, but I would think that being recently rebuilt, this would not be the problem. My next thought is to check and adjust the valves thinking that a tappet has slipped in adjustment. This is definitely more work than the first choice. If this is the likely cause, I am wondering what I need to go through to adjust the valves - pull the pan and work from under the car? I have the Les Andrews trilogy so have the good reference material. Then, I guess the third cause could be a broken made-in-china spring and I don't want to think about that right now...
Ideas or comments? Thanks in advance....
