Howdy boys, I have a question for you "Experts"! In Les' book, he states valve spring tension should be 60lbs (+/-3) at 2.5" compression. At 2.75" compression it should be 36lbs. After speaking with Joe at Snyders, wondering why the new sets I bought tested at 40lbs at 2.5", he informed me that the original Ford specs calls for 40lbs. I called my good buddy Jim Brierley, who has built more engines than I ever hope to, and asked him what he thought. His figures say at 2.375", the compression pressure should be 38-40lbs. So, what is Les referring to when he is stating the spring tension at 2.5" compression should be 60lbs? I did try to call Les, but no answer. I left a message. I'm sure he's a very busy guy, which I understand. Thought I'd put the question to you guys. OK engine builders, what say you?
