The adjustable lifters I'm installing are quite heavy compared to the stock hollow lifters. Also using a mild cam regrind, stock lift with more duration (230 at .050).
Stock spring pressure is 30lbs. closed and 50 open. Thinking about shimming, stiffer springs not available that I know off. Street car, not expecting high rpms, I want at least as high as stock without undue cam wear. Any thoughts as to spring pressure?
