Hook
I just started the process of removing the sludge in my engine by removing the Valve Cover. The pan in next, but I wanted to clean this first before moving on.
I have two questions. First the last valve is in the open position and the spring appears to be at an angle. I hope to attach a photo so you can tell me if this is "normal" when under pressure..
How many feed holes are there in the valve chamber area? I can see three large holes, front, middle and rear. Are there more? I have read previous posts that seem to indicate there are more smaller holes for the cam. I haven't touched the sludge yet as other postings warn not to do that until plugging the feed holes.
The engine seemed to run fine, but most everything else that was supposed to have been rebuilt was cobbled up. When I drained the oil for the first time, I had to poke a screw driver through the drain hole to get the oil to drain. I filled the engine with detergent oil, but have only driven it to storage last year, then to my new "man cave" a few weeks ago. So far some sludge in the valve chamber, but not as bad as I expected.
Thanks for any insight you can provide as I proceed.
Larry
Larry
