You will not see any appreciable difference in going to 1.6" valves over the 1.5" valves - especially if you're doing mild port work (which is probably just cleanup and polishing). It is not really worth the added expense of swapping out all the hard seats just for .050 width on each side.
If you are talking about length, then the stock Chevy length (which is longer than stock Ford valves is a plus). The reason is the base circle on the cam will be smaller, which demands a longer lifter or a longer valve. Since nobody really makes longer lifters (and you don't want the adjuster too far out - if running adjustables), then having a longer valve will help.
Here is some information that I wrote on the HAMB - it will probably help you:
Those of us who have built hot flatheads have probably heard about 'Zephyr' springs, Isky 185G single springs and maybe even the "hot setup" for big cams . . . the Isky dual valve springs. How many of you have ever actually tested them on a valve spring compressor or ran them?
1) Engine Style and Spring Pressure: It if very easy to NOT think about how simple the flathead valve train is -- there are very few moving parts . . . no rockers, no pushrods and not much weight (unless you're running those crap SOLID adjustable lifters). Due to this, you really don't need and don't want much spring pressure on the street - even for a .400 lift cam like the Isky 400 Jr., Potvin 3/8, etc.. This is especially true if you're being conservative on your RPM range and not pushing the top-end past 5500 (which very few people do). Also, the flathead only has 3 cam bearings, so putting a bunch of spring pressure puts unnecessary pressure on the cam -- and on a high-lift cam (which has a small shank diameter or base circle), it wants to deflect/flex all the more.
Putting your 'Cam in the Oil Pan': Lastly, the more spring pressure you run on a flat tappet, mushroom or radius cam - the more valve train wear you get. Want to wear that cast iron regrind out really fast??? - put a bunch of spring pressure on it! Roller cams can take much more, but they are made out of 8620 or 9310 billet steel and are heat treated!
So how much is enough? Well . . . as usual, it kind of depends. For MOST even hot street flatheads, you'll probably not need more than 60 - 70 lbs on the seat. For even more radical cams (not really street cams) - like the Potvin 425, you'll probably not need more than 80 - 85 lbs (with the above rpm range). Even on my blown flathead with a very radical .450 lift cam and steep fast opening ramps, I only ran 90 lbs on the seat . . . ran to 6800 RPM and didn't float a valve.
My good friend (no longer with us) 'Flatdog' with his Crower roller cam only ran about 90 - 100 on the seat . . . with 10 lbs boost in a full drag-race application (.450 lift as well).
2) Testing Installed Heights and Spring Pressure: You can buy a nice hydraulic tester that will work on a drill press or a lathe for somewhere around $80 (I think that is correct - checkout Jegs). It works great:
3) Sample Spring Pressures and Flathead Myths: Here are some numbers to review on spring type, pressure and installed heights. I wanted to check it with a reasonable seat pressure and a "nose" pressure - assuming a Potvin 3/8 cam - .375 or so lift (gross).
a) New Lincoln Zephyr Springs (new) - Reds:
Height: Pounds:
1.950 80
1.575 170
b) Isky 185G (new) - One of my favorite flathead single springs:
Height: Pounds:
1.980 80
1.605 180
c) Isky Dual Springs (new) - What many swear they need on cams like the 404-A, rollers, etc:
Height: Pounds:
1.765 80
1.390 180 lbs
d) Lincoln Zephyr (used) - came out of a 404-A radius cam setup
Height: Pounds:
1.820 80
1.445 150
Here is a picture - with the used Zephyrs on the left, then the new Zephyrs, then the 185G, then the Isky Duals:
So . . . did you notice anything funny in the numbers ?????????????????
How about those trick Isky dual springs? First of all did you notice how SHORT the installed height needed to be to just get 80 lbs? How the heck are you going to end up with a spring height of 1.765? - to do that, you'd need about .200 - .300 of spring shims (unless you ran shortened valves). This is especially true since many of you are using SBC valves in your flatheads . . . everybody is selling them and they are a bit longer than a flathead anyway.
Even when you install the dual springs at the necessary height to achieve 80 lbs on the seat . . . they still have the SAME spring pressure as the single 185G springs on the nose. Also, they are a royal pain in the *** to install - as the outer spring will NOT fit through the guide bore . . . so you "assemble" them with the valve/guide in the block . . . now that REALLY sucks! Talk about one big cussing/swearing fest -- and a lot of bloody knuckles . . . (even with the necessary tools).
If you have a fairly stout street engine - run the Zephyrs, if you have a really big cam and/or a blower, run the 185Gs. Use the approximate spring pressures listed above . . . or not, whatever makes you happy
Installed Spring Height is Key! The numbers that I posted on the previous installment showed that you need to achieve an installed spring height of about 1.950 - 1.980 (depending on which spring you're using and how many lbs you want/need on the seat). If you're running the typical SBC 1.5" pro-flow, better than a Ginzu frigging valves . . . that anybody can buy from anyplace . . . but the flathead web sites sell as if they have a "special part" just for you . . . then you're running a valve that is about 4.910 or so in length. The stock flathead valve (if I remember correctly
) is 4.810 in length - so you're already .100 longer . . . which means MORE spring shims.
So lets take a typical combination of SBC 1.5" or 1.6" 4.910 valves, Lincoln Zephyr springs and a desired installation height of say 1.950 or so. Well, without ANY spring shims, running stock retainers . . . you'll have an installed spring height of over 2.1 inches - this is WAY too weak! (I know - depends on your engine, the one I just did was about 2.150). That means you need three .060 shims and one .030 shims . . . lots of them stacked up like a bunch of nickles. If you buy the Zephyr springs and complete valve package from places like Reds . . . they throw in one .060 shim per valve -- not even close . . . (you'd think they'd know the issue . . . guess not!)
Solving the Spring Height/Retainer Problem: Don't just slap the damn valves, springs, retainers together . . . cause you bought the kit and that is all your have to use
. . . get off your butt and buy some aftermarket chrome moly retainers (Comp Cams: 743-16) - and turn them down on a lathe to end up with the following:
a) The correct installed height - with probably NO shims
b) A nice chrome moly retainer . . . much better than the stock stuff.
c) A much cleaner valve setup with a nice tight fit between the valve spring and the retainer. The inner valve spring area of these cut-down retainers fits a flathead Zephyr or 185G spring perfectly!
Here are some examples of what I do - using the Comp Camps chrome moly retainers --
part number "743-16"
a) Mount them in a lathe
b) Turn the OD down to match the OD of your Zephyr or 185G springs
c) The spring will have a tight fit on the inner spring location of the retainer.
d) Put a valve, guide, spring, retainer, lock assembly together.
e) Install it in your block and measure the installed height - adjust as necessary. The thicker retainer will be equal to 2 - 3 thick shims . . . you may still need some, just depends on the lbs you want on the seat!
f) Tip: It is nice to have a weak 'test spring' - that you can just compress by hand during the 'fit up' stage . . . makes life easier.
Here are some pictures:
Here are pictures of a stock, modified and Comp-Cams moly retainer - see how they've been turned down:
Here is the complete assembly - ready to go . . . nice and clean. I still needed one thick shim .060 and one .015 shim . . . better than 5!
This should help yah!
B&S
