51merc
pardon me for asking everytime i hit a bump in the road, but....
the manual describes removal of valves basically as follows:
"...pry guide downward," (apparently pulling it down out of the block a bit,) "until the guide retainer can be removed. a wire hook should be used in removing the retainer."
then to "...pry guide upward," (apparently pushing it out of the top of the block)," and lift out the valve assesmbly"....apparently only minus the guide retainer. then of course the entire valve assembly can be dismantled.
now i've also found some other hands on suggestions (from this forum and others) to compress the spring, upwards from the bottom of the valve, and pop out the valve retainer keys, which are 2 pieces in the manual. however, my '51 merc valve retainer keys are one-piece, so is there anyway to get them off of the bottom of the valve, while still in the block?
if i can get the valve assembly out, from the top, then i can use a socket or something similar to tap the valve guide down thru the bottom of the block, or at least to maybe free them up and get them out
i don't have a "pickle fork" compressor bar, and i do see how the need for one will necessitate ordering one, and i'm gonna, but...i've been using pry bars in an attempt to catch hold of the guides and pry them down, but it don't wanna hold good enough.
