dpson
As a follow up to my recent "Bent Valve" posting, in checking the valve clearances for the other seven valves (non-adjustable tappets), five were good ranging from .013 to .015, however valve #2 (intake) was .025 and valve #1 (exhaust) was .052. Yup, no typo .052. Most of the bell end was ground away (not worn away, see photo), so much was gone they has to insert a stip of metal around the end of the valve to keep the valve spring keeper from hitting the tappet. I'm scratching my head as to how someone could get the valve clearance so wrong? No wonder there was a loud clacking coming from the front of the engine.
Also found the answer on grinding the valve stems, picked up an old Kwik-Way valve grinder on Craigslist for $80. It's an older model (P), made between 1939 and 1950, still works great. These were a well made product, it has 18 oiler locations. BTW: Kwik-Way is still in business out in Iowa.
