walt jones
When Model A valve seats are ground should a single angle grind be used or a multi angle grind to narrow the seats ?
With a Neway seat cutter, gives much better finish and is more accurate.If you're not well versed doing these angles, get a seasoned machinest to do them.
Bill W.
Someone just had to go beyond what we were talking about. We , I thought, were talking about a long lived reliable valve job on a Model A or some such similar low performance flat head motor.
Talking about modern technology and high performance engines is a different conversation. Thats a good conversation to have, I just didn't think it applied here. JMO. Sorry to get involved.
I've never given a thought to power increase in connection with the 3 angles. # angles are needed to establish the correct width of contact between the valve head and seat. How far you grind the top and bottom angle will determine where the seat contact area meets the valve. I want the contact area just slightly out from the middle of the valve, as the valve will expand slightly when it gets hot.
There was an International tractor shop near me years ago that only ground one angle and never cleaned the grindings out. I would never have had them do my work. Maybe they worked that way to get repeat business.![]()
