Randy Lausch
Putting a new head gasket on a 4 cylinder Model A I decided to check the valve clearance . Two of the intake valves had 8000 clearance, I wonder if anyone knows how critical that clearance is. I believe they are supposed to be 1300. It seems to run good, before I tore it down. Should I tip the valve stems or leave them be. Thanks Randy
