telmore1964
Hello, I have recently purchased a 1930 Model A pickup truck about 3 weeks ago now. The truck came with an electric wiper motor and I was trying to determine how original this would have been. There is no vacuum piping or hose inside the cab nor is there any inside the engine compartment. In fact the intake manifold doesn't even have the vacuum port installed. I was wondering if Ford would have sold new Model A's like this? There is a hole near the sediment bowl in the firewall which I assume would be for the vacuum line to pass through though. On the windshield there are some holes that look like they were drilled by someone in an attempt to install the electric motor and I would speculate they are not original. Also the U shape notch on the inside of the windshield frame where I assume the control knob and shaft for the vacuum wiper motor pass through are not drilled to outside at least there isn't a matching hole that lines up with it and lastly I don't seem to have a hole for the vacuum hose to pass through and it doesn't appear there was one then later patched up.
Thanks
Tom Elmore
Anchorage, Alaska
Thanks
Tom Elmore
Anchorage, Alaska
