30ccpickup
I have an unmolested, low mileage 1938 coupe. I was hoping to get it running well and take it to the spring event at the Early V8 Museum to discuss what to clean, what to restore and what to leave alone. The goal is to collect as many opinions as I can before I proceed with my vision. With that said, I have the headliner open above the window header to remove a mouse nest. Since it is open, I plan to oil the vacuum pump mechanisms and feed the inwards of the pump with a little atf.
The dilemma: the hoses are stiff (but not brittle) and leaking air around the connection to the vacuum pump. My mind has it to wrap the hose with pinning wire and twist until it seals. Hopefully the wire will not cut through.
1. Does anyone have other suggestions/solutions?
2. Is there a chemical I should use to condition the hoses with before I proceed?
3. Another thought: I could leave it as is and just use Rain-X.
Opinions are welcomed.
