Mine worked OK on the '51, but someone on the H.A.M.B. posted about using brake fluid as a temporary fix. Get one of those ketchup squeeze bottles from the Dollar Store and fill it about a third of the way with DOT 3 or 4 brake fluid. Disconnect the wiper hose at the carb and put it over the spigot on the squeeze bottle. Manually run the wiper blades back and forth several times to suck the brake fluid into the chamber (the wiper motor is functioning backwards). I continued until I saw a drip of brake fluid on the floor mat (I tend to overdo things). I put it back together and couldn't believe how much better the wipers functioned; I can live with them now.
Make sure you are careful around the paint with the brake fluid and label the bottle and don't use it for anything else, ever. I probably should have crawled under the dash, removed the wiper motor, cleaned and lubed it, but at my age, that ain't in the cards. I can now go up the County Road 11 hill out of Breezy Point in a rain shower, and can see all the way up, if I time my shifts properly.
Ralph, make sure the wiper hose is good and supple. You may just want to replace it, as it's cheap enough and easy to do.
