Vacuum operated windsheld wiper motor
Winter
New member
On my 1930 Model A Sport Coupe my wiper works very slow and stops
intermittently. Also, the arm wire to the blade is very rusty. I have checked the vacuum line. I need advice on how to get this fixed in case of rain. Thanks
RainX- try some 3 in 1 0il in the wiper line/wiper:confused:-reattach and try?!
The vacuum wiper motor actually works by atmospheric pressure pushing on the internal vane. Somewhere on the motor is where the air enters. You can try spraying a good penetrating oil over the motor while it is working. The oil will find it's way into the motor along with the incoming air. That may free up the motor so that it will work correctly. If not, then you must disassemble the motor and rebuild it. Or send it to someone who can do that.
I use a vacuum pump instead of running the engine. If you use a vacuum pump you can work on the vacuum motor on your bench.
The windshield wipers on Model A's have a reputation of not working very well. That is why Gary recommended Rain-X, above. The problem seems to be the blade. As far as the rusty arm goes, you can sand it to remove the rust and then paint it with a silver paint.
Vacuum type wiper motors have always had problems with function when the engine is in a high load situation even when the things were new. Add a bunch of years to an old zinc die cast body that likes to warp and a rubber paddle assembly inside that likes to deteriorate then the situation just gets worse. Some say mineral base ATF is a good lubricant. Sewing machine oil works OK. If a person takes it apart and cleans it up then vaseline can be used in the paddle pathway. A person needs a gasket kit to put it back together. The fact that it functions at all is a good sign.
When I was a kid, our old family 51 Merc had a vacuum pump with the fuel pump to provide vacuum under all conditions. On my old Ford and Chevy pickups, I just let off the gas to get a few wipes while it was raining. We didn't have rain-X back then. If you had to pass a car then you were taking your life in your own hands. We just slowed down if it was raining very hard.
Those electric kits have been out of stock for quite a while. They just used a modern aftermarket wiper and made a bracket on the milling machine for it to mount with. I think it could be done without a mill but it would take some precision hand work to get it right.
