I would think alittle common sense would set in about now. For max power you need approximately 20 degs of advance at 2000 rpm. JWL ran dozens of WOT dyno tests and found tjis to be the optimum. Agree, not all engines are the same so this can vary some what. For thse that have taken advantage of higher compression and a tighter chamber, this number becomes critical. Most street engines have increased displacement, higher CR and a longer duration camshaft create a different requirement for the ignition system. Because of this modern engines have computes that regulate the fuel flow and ignition advance depending on engine load.
We don't have that luxury, we're stuck with a distributor and a carburetor.
Richard has mad an engine monitor that displays the RPM, timing, vac,and AF. This is recorded for future observation. Over the past few years we've given thin information to everyone interested and shared here on the Barn. Now most of you foks don;t have this kind of instrumentation, so we make it easy for you to do this with just a timing light and a tachometer . The following is a simple way to set up your engine.
Now some of you may be running a ot cam like the L-100 and the vac at idle will be jumping around abit. Install a plug in the vac line with a small hole in ti like .060" this will tame down the effect of the cam.
I probably missed something but some one will probly jump on me, like Richard.
1. Install the modified SBC dist with adj Vac adv. do not connect vac
2. run engine up in rpm and using timing light, determine the amt of advance.
3. If more than 22 degrees send back for adjustment to 20 degs.
4 set dist at idle to 2 degs
Run up in RPN and check for max adv and rpm. If over 2200 rpm send back to mfg.
5. while the eng is idling, add vac to canister. timing will adv the amt set in the canister. You can adj this with the Allen wrench supplied, start with 6 degs.
In my case the finished timing was machanical advance 16@2000
Vacuum advance 8 degrees,
Have fun
