Vacum wipers slow
Ford coupe
Is there any way to speed up the vacum wipers on my 55.Probably needs to be rebuilt or?? Cani spray something in the lines?Thnks
With the motor running and the wipers on, put a hose on the bottom hose fitting, this is the intake for wipers, not the vacuum hose to intake, put a small cup of brake fluid on floor and put the hose into it, the motor will suck the brake fluid through the wiper motor and clean and lube it and goes into the intake and burns and out the tail pipe. Works for me.
