V8 Trans in Model A
Richard in Anaheim CA
I am just finishing up installing a V8 trans in my 28 Tudor an hope someone out there can solve a last minute problem for me, installing the 28/29 stop light switch on the transmission.
The larger V8 trans leaves very little room to install the stock switch. Does any one have a solution for mounting it, if not maybe an alternate switch?
Thanks
Richard
Anaheim CA
Howdy Mate, good to hear from you,hows things,you and Jeanie firing on all cylinders.
I use a hella brake light switch on my A,just mount a small bracket off the frame or gearbox top and connect it to the brake pull rod by a spring.
let me know if you want a pic,but you may have to turn it over as mine is upside down here.
Lawrie
Stop Lamp Switches
4560 Stop Lamp Switch
4562 Stop Lamp Switch
4565 Stop Lamp Switch - Hydraulic
4566 Stop Lamp Switch - Hydraulic
4567 Stop Lamp Switch - Hydraulic
4568 Heavy Duty Stop Lamp Switch - Mechanical
4569 Stop Lamp Switch - Mechanical
4570 Stop Lamp Switch - Mechanical
I really don't understand changing to a later transmission. My transmission has been working faithfully for 88 years. I have no problem driving it. Smooth shifting and good gear ratios.
Lawrie,
You have a hell of a stop light switch? Yes, I would like a picture of it. Yes, I will turn it upside down like the Aussy flag you gave me is hanging upside down in my garage.
Chris,
I have driven all my model As with stock transmissions for over 50 years now. They are fine but I can't agree with you that they have good gear ratios.
The 28 Tudor has been driven, by me, in 49 states. It's driving to the last one, Alaska, this year, with a V8 trans.
There are a few newer upgraded synchro transmissions with nicer ratios that bolt up to the the old girl ... just need to drop a bit of cash .. see Snyder’s
Richard, on my '30 tudor I turned the switch 180 degrees and wrapped a small wire-rope around the pedal-arm so it pulled the switch to the off position. This puts the switch behind the crossmember and out of the way.
I have used an after market brake light switch for an old mechanical brake Harley Davidson.
Easy to mount. It also uses a spring to pull the switch. Google Drag Specialties they carry them. They are also on eBay.
Richard,here is a pic of the Hella b/light switch.it also has a little rubber boot to cover the terminals.
Lawrie
Thanks guys. I needed that.
Doug, I'm aware of others It's the $$$
Jim, Thanks. I'm not quite picturing that yet but will try to figure it out. Doesn't the 30 have the brake switch on the back of the cross member already? I may just have to come out there and take a look for myself.
Dodge, thanks. I'll check it out. Never thought I would have a "Hog" switch on my A
Chris, you can certainly comment any way you want. To understand why I am doing it?
Different strokes for different folks.
Lawrie. That is beautiful. Do you have a part number?
Briphaeton. I don't seem to have enough room. Do you have a picture of yours?
Thanks again. I never answered more than one at a time. This is fun.
Richard
