10 years ago I ran several different syncro transmissions in one of my cars using a B engine and trans. The gears are the same as the V8 and the conversion required most of the adapter parts, less the flywheel housing adapter.. As mentioned above, the early transmissions shift slow and have problems staying in gear due to a poorly designed syncro hub. The "39" gears, which were made until 48, are better. As a result, they are more in demand and are costly, especially with a top loader, as its popular with hot rodders and rare. After all the expense of buying the conversion parts, rebuilding the syncro hub, bearings, spacers and shafts to the correct specs, and the work involved, its not a bad combination, but the Mitchell with a 15 percent higher second gear would have been a quicker and easier conversion and would not have cost that much more. It would also have been a new transmission, not a rebuilt old one. If you do not get the correct space between the second/third slider and the syncro hub on a V8 transmission, it will slip out of gear. Finding the correct spacer and doing all the fitting is very time consuming. You will also have to modify your floorboards and make a metal cover to accommodate a V8 ******. Bottom line: if you run across a great set of gears, find a 40 pickup floor shift top cheap, like the work and have the time, go for it: if you want a syncro trans that just drops in and works like new, get a Mitchell.
