v8 pressure plate adjust
Ordsgt
I had purchased a rebuilt model A long block. It came with a balanced lightened V8 flywheel and pressure plate. I have not found the specs for adjusting the pressure plate. It is not installed on the engine. Where can I find the procedure/spec for the adjustment?
Could you please tell me where you found the pressure plate adjustment post you were looking for as I too have the same issue. Many thanks.
