A regular treatment, long ago, was the use of 'top oil' it was sold at stations everywhere. Made by everyone. A small can would be poured into the gas tank to keep the valves working freely. These days when there is a concern with sticking valves we turn to Marvel Mystery Oil. The prescription on the bottle calls for 4 oz. per 10 gallon gasoline. It works.
Some have reported, in extreme cases, of introducing a small ( be careful here-do not want to cause death by hydraulic lock ) drizzle into the carb while running at a high idle. This can help to unstick valve(s) on a motor that has been left to sit.
Those that use MMO on a regular basis don't experience valve operating problems. We do, however, have to put up with the naysayers who can't appreciate your observation of the oil flow not being directed to the top.
Mart and JSeery are correct that splash does an incredible job of moving oil inside the motor. My avatar has NO oil pump other than the the magneto magnets and the crank throws splashing the oil all about.
Once I failed to tighten a starter bolt on the 'T'. The immediate result was an oil puddle, the same as an improperly fit full flow filter.
