If you're racing you shift just before the engine begins to flatten out, havee to stay on the hi side of the torque curve. Some trans have a very low 1st gear and when you hit second your already on the wrong side of the curve. You can only get the hang of it by looking at the timing sheets and blowing a few engines.
I used to shift at 45 hundred but after everything converted to thousands I switched to 4 and a half thousand and it goes much better.
Mart.
So on a old tach , 100's are the same as 1000's , Example 200 rpm is now 2000 rpm.
A stock (( 1950)) 239 is about 110 hp & 190 torq @ 2000 rpm's ,
Around what Rpm does the vale's start to float .
I am looking for a Vintage tach , but I don't know if need just a 4 hundred or 4 thousands tach reading ,or 5 , or 6 ,
I have plenty tach's that go up to 8,000 - 12,0000.
Mart.
As far as I know there is no such thing as a 4 hundred tach (at least not automotive), the engines idle faster than that! The range you would need on a tach depends on the engine and what you intend to do with it. On a stock Ford dyno chart the engine hits max output around 3500 rpm (less in the real world) and the charts end around 4500 rpm.
Where RPMs read by 100s or Thousands on early Fords , if so what year did they go to thousands ?
@ gen in x100s ?
@ crank x1000s ?
How many RPMs 1000s Or 100s do you turn on your stock Flatty when you are going threw the gear's (8,500)A Rod Kicker !!!
There is no old and new way of illustrating tach faces. The maker just has to show how many revs per minute the engine is turning. For example, in your pics the second one is numbered 0 to 30 and clearly labelled "hundreds" it is a 0 to 3000 rpm tach.
Some are numbered 0, 1, 2 etc and would be labelled "Thousands".
There is no set pattern or late and early type.
Mart.
Duhhhhhhhhhh!!!!!!!
I'm a dum -SS ! I compleatly over looked at the reading's ...
I just focused on the Where it said HUNDREDS![]()
I'm going to completely disregard this thread. Hoping it's all a joke.
No Joke !!! The first question was answered by Mart from the Original post ,
There where 3 question's ,, I over exsamaned & only focast on the Hundreds RPM marked on the faces of several tach's & did not look @ the number layout
Mart's quote
**********I do apologise I thought my attempt at humour would illustrate that the two types of readout give the same result.
All is good though, we got there in the end.
Mart.
