I am happy with my stock clutch and flywheel. The Snyder page says, "benefit of a V-8 clutch is less chatter and less effort to engage" The conversion is popular, but is it that much better?
I think it can be, ...but with a 'but'.
Over the years we have assembled a lot of cars that had varying combinations of flywheels, pressure plates, crankshafts, rear axle ratios, etc. My thoughts are that many hobbyists have ruined the core of what made the Model-A what it was famous for. Granted it is a different world today, but the Model-A was always known for being a good hill puller, and being awesome in traversing mud or soft sand. Because the camshaft was designed to make low-end torque, and because of the mass of the heavier flywheel, this made a great combination. Today, many Model-A camshafts are either worn, or have been reground where the engine has lost the ability to make torque at a low RPM.
Next, most people that I have either observed or heard driving their Model-A really do not shift them properly. While Ford designed the Model-A to have the 1st to 2nd gear shift at 5-8 MPH, most hobbyists take of by engaging the clutch with the engine revved well over 1,000 RPMs, then rev the engine towards the moon until they have reached about 20 MPH, so they make the 1-2 shift ...all the while grinding and forcing the shift.
For the ones that are a tad more patient, they allow the RPMs to fall until the shift is forced into 2nd with a tad less effort. The same thing applies when they choose to shift to High at speeds somewhere around 40-45 MPH. So for these drivers, a lighter flywheel is definitely superior.
As for other reasons, I started a thread several years ago that I feel discusses all of this pretty thoroughly...
https://www.fordbarn.com/forum/showthread.php?t=89197
