Hey Guys; I am normally over on the Model A site, however a good friend of mine has a Model A with a V8-60 (early model with the sheet metal water jacket). Any way, the right hand water pump is leaking water behind the pulley and making quite a mess. It's getting on the top of the distributor. How do you go about stopping this type of leak? If it was my guess its the front pump seal. Can they be replaced or rebuild the complete pump? Should you do both pumps at the same time? Help! Where do you get parts?
One more quick question. What kind of 'Top' is supposed to be on the distributor? Right know the condenser is visible and it looks as if the 'Top' is made of Aircraft micarta. Flat with one bolt and then the coil wire, with the condenser.
Thanks; Tom - ATL
Thanks; Tom - ATL
