Fresh build everyhting seems good however.
The oil pressure is stable at 40PSI above 2000RPM
It remains there as the engine worms up. Just as the engine reaches full operating temp. The oil psi drops to may 5psi. I have used a mechanical gauge to verify pressure.
The relief spring look OK, I did shim it a tiny bit. but the oli pressure is perfect until peak operating temp.
Could the spring be losing strength when it heats up?
I am at a loss on this. Has anyone ever had this issue?
Thanks
Tom
Thanks
Tom
