Paul Bennett
I am neatening my existing under-dash wiring AND getting ready for 12v and a new engine which will have a 1-wire alternator.
The battery wire thru the ammeter ( already reversed) connects to an under dash distribution block. Right now the block gets generator juice from the B terminal of the Voltage Regulator. The B terminal is where the alternator will initially connect with the generator wires from the other terminals removed.
After cut over from Generator to Alternator I'd like to eliminate the entire Voltage Regulator as it's just an eyesore on the firewall and is electrically redundant.
question: Have any of you with a 1-wire alternator removed your VR? Comments?
