skip
At The Door County Maritime Museum Classic and Wooden Boat Show a fellow brought in a Ford Flathead V-8 on a pallet. The engine was pulled out of a boat. It was fitted with the following strange items;
~A stamped steel oil pan designed for a vee drive shaft. I'd guess 20 degrees. This allows the block to be at 20 degrees with a horizontal flat bottomed oil pan.
~A cast aluminum in take manifold to bolt to the canted block but allows the one barrow carburetor to sit flat and up right. Like it would in a car. I believe a fuel pump also mounted 'square to the world' on a slopped intake manifold landing that was flat.
~Cast iron jacketed water cooled exhausts bolted to the three exhaust openings in the block. Looked like both cooling water and exhaust meant to expel through a transom. These castings did have a name embossed on them. Darn if I can remember the name.
~Two water pumps, they looked normal with the exception of an added street el drilled and tapped on the discharge side of the pumps. Hoses lead to exhaust manifold to fill the exhaust jackets.
~A cast bell housing that was fitted with an exposed cone shaped clutch on an arm that pushed the cone 'IN' to engage. Pulled it 'OUT' to disengage from about six fingers that made contact with the cone. Fingers were on the input side of the reduction box shaft.
~A driven reduction box. Ratio unknown. Had an arm on it for Forward-N-Reverse. Output side had a keyed shaft with a disc for six bolts. I assumed the matching disc was for the prop shaft going to the cutler bearing and stuffing box.
A neat set-up. The guy wanted $600.00 for it. Said he never heard it run. Didn't know if it ran and the engine had a distributor 'tween the water pumps; well kind of 'tween the pumps that looked like a spider. What a rat's nest. He did sell it at the show.
Anybody have additional knowledge? skip.
