48fordconv
Which NGK plug should I use in my 48 Ford with Edlebrock Alum heads?? Also what Gap should they be set at ?/ Thanks I had this written done someplace. Had car worked on they put Champions in.
NGK B5-ES are 3/4" length. Just right for Flatattack heads, and others.Steve, I'm using the B5HS NKGs that are a bit hotter than the B6s in my old Weiand 8.5:1 heads. NKG's lower numbers are hotter than the higher numbers. The HS plug is a bit longer reach (1/16") than the L and would probably fit the older Edlebrock heads better. My new Edelbrock heads require a 3/4" reach plug and I haven't yet found a plug recommended for these new heads.
