- City
- Temecula
- State
- Ca
- Price
- $800
Pretty complete used 1929-1931 Ford 4 banger engine with starter,exhaust and intake,water pump,carb,generator,distributor,bell housing,gas pedal assembly,water outlet,Edison spark plugs,brake and clutch pedals.Engine is not stuck..Comes with multiple transmission cases and gears.Crank shaft needs a new or used pulley..Cylinders are being soaked with ATF to keep cylinders and rings lubricated.I have a hoist for loading..Will need the usual prep before attempting to start it. Good backup engine to prep for future use..760-717-1334
