Crankster
Whoa Crankster,Isn't it true a Mars Orbiter failed because one engineering department was using "English" measurements and one was using metric??!!
People make mistakes, if that's what your point is. Scientists convert from different measurement standards all the time, it isn't cause for comment.
Unless somebody &$@s up, of course. Aircraft for example, generally measure fuel in pounds (weight), not gallons. Woe to the aircrew who plugs in the wrong units to determine range or perform a fuel consumption check. This has happened, with disastrous results.
