I used a kit from classtiqueupholstery and was disappointed.
Can you explain with a little detail?
I am interested if Model T Man was dissapointed by quality of work, timing or as you said little attention to detail. In other words should I order from Classtique or L.B.?
I'm a pretty good judge of character and first impressions are foremost. Call and talk to both companies and make your decision. Take into account that everybody can have an off day. I went with Classtique but nothing negative from LB.Neither is 100% so in my opinion, take your pick.
A) That is my problem. My knowledge of what was original in this 160A is minimal.
B) ...and I believe in 1931 there was a assembly building for the Model A here in Houston.
C) Back to topic. I am not a purest but would like a accurate upholstery kit thus need some input on the two most obvious choices by private email if necessary.
In the 70's , Vaughn's in Greer SC was as close to original as you could get .
No, I am not an authority on interior products. This will be a driver and not a points car. Just make it look and feel good. For the rest I'm glad to have others more experienced that me.Again, IMO the issue is not necessarily the customer service, -but the Q/C and the details of the product itself. Theoretically, a company can be the kindest & and most prompt seller there is however if you are expecting one thing however they ship something else that is not the same in details as what you were expecting, then there is likely to be disappointment.
...AND with that said, Dan if you were to call and ask questions to them about a Tudor interior, do you feel you know enough about the authenticity of what your car had originally to ask the upholsterer those questions??
One of the best ways to make my father mad was to let him catch you using
his tack hammer to hit something ., I can see him now with a half a tube of
tacks in his mouth ,.,
In the 70's , Vaughn's in Greer SC was as close to original as you could get ., I used to drive over there just to see cars waiting to get in the building .,
