Mike..Yorba Linda
Never bought a Cartouche kit. Will it come with foam? For a ‘56 Ford F100.....Thanks...
Thanks....I had a hard time contacting the company....if no you may contact an upholsterer near yourself as I am sure they only supply the cloth as most do.you may find the foam will need to be shaped from a slab using an electric knife type tool then sanded into shape. good luck
