Ronnieroadster
Ok I get it
Wondering if there are any FH racers out there?
What type of oil filtration system are you using?
Again, not trying to disrespect anyone
Simply looking for info
Its simply a matter of what one prefers to do. A bypass system is Okay. The 95 percent system is better. Those of us who use our Ford flathead powered cars a lot like myself prefer to use the 95 percent conversion the filter I prefer for the conversion is the Ford Motorcraft FL-1A.
Sure its a bit more work converting to this improved system but its not a difficult job for the average individual to do with some care and good mechanical skills.
My experience after driving cross country and back first time 6000 miles the second trip over 7000 miles most at highway speeds there was no internal wear what's so ever. Since I have driven my roadster over 100.000 plus miles so far I'm pleased with the longevity of the internal parts. An additional item that helps greatly as mentioned above is a PCV.
One needs to think about what's taking place in our engine's. While we know the cubic inches of the engine's size that same cubic inches is actually being pumped on the downward stroke into the crankcase. Thus the blowby and crankcase pressures are an area that's greatly improved when a PCV is added into the equation.
Ronnieroadster
