30RoadTom
I have removed and disassembled the water pump to find the source of that silver discharge. The water pump shaft looks OK and the grease in the bearings is black, so no grinding in there. Although I am concerned about the 'ears' of the impeller which seem to be worn down, though I can't find any matching wear spots inside engine. The inside of the fan pulley has obvious wear, but aside from the missing paint there is not much metal missing. The outside nose surface of the pump does not really show any wear. You have to look closely at the ground down weld seam on the top of the housing to see a small area that is slightly more shiny than the rest of the seam. This must be where the pulley was contacting the housing. So it seems my biggest problem is the amount of grease coming out of this area (with just enough metal in it to color it silver). Enough where there are now little specks of silver grease all over the inside of the hood. I intend to use a shaft collar with nylon washer on reassembly to eliminate the horizontal movement of the shaft. I'm also going to try the new type neoprene seal on the packing nut instead of the old style rope packing. Do you guys think that by installing the collar, and reducing the horizontal movement, would be enough to greatly reduce the amount of grease escaping? I don't want to replace the shaft unless I have to and I don't want to disassemble the bearing to replace the felt washers if I don't have to. Thanks for your input.
