My Brassworks radiator maintains a constant 135 degrees (without a thermosat) up hill, down hill, timing advanced, timing retarded, on the turnpike at 50 mph on a hot day and maintains a constant 165 to 170 with a thermostat installed. Its worth it! Spend the money! I spent months try to make my old radiator work. It only worked after I removed the head, changed the leaking head gasket and cleaned out the water jackets. But after all that effort, all I had was a marginal radiator that just barely kept my enegine from over heating. Take the plunge, remove your head, clean the rust out of your water jackets, change that head gasket and buy a new radiator. You will be glad you did!
