Tom Wesenberg
Last summer a guy gave me this tool. When I looked at it I had no idea what it was, until he told me it was a piston knurler. It reads:
SEALED POWER CORPORATION
PAT.PEND.
And on the top side near the handle it reads:
HKSCo
Newport, KY.
Notice it has a wingnut to adjust the tension on the rollers. The bottom roller in the picture has a sharp edge, like a tubing cutter, and the top roller has a 1/4" wide by 5/8" diameter roller. I assume you turn the engine until the piston is down as far as it will go in the cylinder, then run this tool up and down the exposed part of the piston skirt. I'm not sure of this however, as I've never seen or heard of a piston knuler like this before. Does anyone know for sure how to use it?
Thanks
PAT.PEND.
HKSCo
Newport, KY.
